redid my intercooler water system for cheap
Old 09-25-2008, 06:10 PM
MIGHTYMOUSE's Avatar
Default redid my intercooler water system for cheap
i got 200 wrapped up in everything, very satisfied
not sure why i dont see a lot of people using poly tanks.. but i figure they dont make aluminum drink coolers for a reason
sure the plumbing parts look a little funny, but 25 bux for all fittings is much more attractive than 25 bux for EACH fitting.
i put a union on the return line so i can unhook and throw it over the side of the car to pump all the water out easily.
the hardest part was finding the magical spot to send the hoses through the firewall
action vid will make you want to pee!
http://upload.streetfire.net/video/i...ank_186951.htm
plan was so i can pull all the junk out of the cab of the car in about 5 minutes all the way up to the firewall, and cap off the water that is in the front half for street driving
Old 09-25-2008, 06:14 PM
White.Lightning's Avatar
Looks nice Dave. Its cheap and easy to remove like you wanted.
Old 09-25-2008, 06:18 PM
daniel6718's Avatar
im sorry but what was the advantage? just that you can run extra water?
Old 09-25-2008, 06:30 PM
-can take the 30# out of the car when street driving in 5 minutes
-has 2 gallons (roughly) more capacity
-has bigger mouth, easier to fill with ice
-has higher flowing pump, bilge style vs self priming (also draws less amps)
-happens to be quieter
-can refill with ice or water without popping the hood (against rules in some classes)
-plastic insulates the ice better than aluminum tank
-ice lasts longer sitting in cabin vs under hood
Old 09-25-2008, 06:34 PM
bgblockelcamino's Avatar
nice work. been a lot of good ideas in the forced induction section lately i like it!!
Old 09-25-2008, 06:46 PM
7 Second Club
Phil99vette's Avatar
Nice tank, where did you get it from?
Old 09-25-2008, 07:31 PM
a non sponsor!
70 for the tank w/ fittings and another 25 or so for the lid (pre-installed for free tho)
Old 09-25-2008, 07:51 PM
frcefed98's Avatar
Dave its alright to post where you got it from if sponsors here don't carry the same or like item.
Parker hose and steel fittings? I used that stuff for my fuel system....saved a ton over SS line and aluminum fittings.
Lookin good
J
Old 09-25-2008, 08:06 PM
thanks guys
pvc and cpvc fittings, radiator hose from lowes
tank from http://www.tankdepot.com
clear hose stole from work
rule pump from grainger
edit out what you like
Old 09-25-2008, 08:18 PM
Hennytime's Avatar
damn thats awesome, start selling these
Old 09-25-2008, 08:30 PM
SSilverSSurfer's Avatar
thats neat, you should put a neon light around the hose for the night time, lol
Old 09-25-2008, 10:20 PM
Frost's Avatar
it's quiet with the lid on, but when it's open, it sounds like a toilet at the bottom of a flush Very cleanly done though.
Old 09-25-2008, 10:30 PM
K9Kev's Avatar
Good thinking and nice job running the plumbing!
Thanks for the ideas.
Old 09-25-2008, 11:39 PM
Z06PSI's Avatar
Similar setup I am putting together but using a Jazzy 3 gallon cell in the back and common hose with a 3 way valve for inlet and outlet to the stock reservoir.
Old 09-26-2008, 12:27 AM
NemeSS's Avatar
very innovative,
thanks for another great idea
Quick Reply: redid my intercooler water system for cheap
