Nitrous On a Turbo car
Old 09-26-2008, 08:13 PM
projectcam's Avatar
Default Nitrous On a Turbo car
How many guys out there use nitrous on there FI car? I plan on using a plate kit on my car to help it 60ft and am wondering what kind of results I will see.
Old 09-26-2008, 11:21 PM
OUTLAWZ RACING's Avatar
Well ummm.. what are the details of your set up? NO2 and boost on a v8 is a little wild.
Old 09-26-2008, 11:24 PM
ModularTurbo's Avatar
Can you say "instant spool" LOL
Old 09-26-2008, 11:48 PM
projectcam's Avatar
Nothing special, 347 with 8-8-1 compression and a th400 with a trans brake, Turbonetics gtm-78mm. I want the car to 60ft in the 1.3 1.4 range.
projectcam's Avatar
I got that wastegate today man. Good stuff!!!
Old 09-27-2008, 12:00 AM
SuperZ's Avatar
I ran a regular wet ki ton my old setup for about 2 years with different shots.Went in to the mid 9s like that.
Old 09-27-2008, 12:02 AM
projectcam's Avatar
Nice, how did the nitrous hit?
Old 09-27-2008, 12:23 AM
Hey projectcam
I am a dealer for NANO (nitrogen assisted NO2). If you are going to run spray on a FI car I would suggest using it.
Old 09-27-2008, 08:01 AM
Cmarsh's Avatar
Hey projectcam
We just tested a Nano system at the shop last week on a KB 2.8 car. On the exact same setup, same pill....it picked up 70 rwhp. Thats going from 700 rwhp to 770 rwhp on 1 stage. I was impressed to say the least!
Old 09-27-2008, 08:13 AM
Race your car!
JL ws-6's Avatar
project cam nice avatar. That's my car LOL.
Old 09-27-2008, 11:59 AM
projectcam's Avatar
I know, its a good picture!
Old 09-27-2008, 12:00 PM
projectcam's Avatar
For those of you that have used nitrous, did you guys spray it into the motor or intercooler?
Old 09-27-2008, 12:08 PM
Black X's Avatar
Project Cam My truck will be a good reference for you.
370 Cube
76MM turbo Remote mounted
3000RPM converter and a FOOT BRAKE
Truck will only build about 2-3PSI on the foot brake before it wants to start sliding the front tires.
I use the NX boost referenced controller and usually spray a 100 until 6psi.
Sixty foots no bottle 1.7
Sixty foot on 100 1.51
Recently I started runing a 50 hit the whole track
went from 10.44@134 consistantly only sprayin till 6lbs boost.
to 9.97@138 with only a 50 shot.
I also have sprayed a 75 shot and went 143 mph with no changes in boost level which is 13lbs.
Hope this will help you!
Old 09-27-2008, 12:27 PM
I wouldn't spray at the intercooler thats just me though me. My .02
Old 09-27-2008, 12:30 PM
projectcam's Avatar
370 Cube
Thanks for the info man, thats the kind of numbers I wanted to see.
Old 09-27-2008, 12:32 PM
projectcam's Avatar
I wasn't really leaning towards. I alrteady have a kit I planned on using. Anyone spraying a 150 with a window switch?
Old 09-27-2008, 12:47 PM
Josh@PremierAutosports's Avatar
I have been thinking about put a small 75-100 shot on mine for the rest of the season. I'm getting close to the limit of my intercooler and plan to switch to a liquid to air. How much nitrous is needed to cool down the intake change on a car making 1200fwhp? I just want it to cool down the intake.
Old 09-27-2008, 12:54 PM
Black X's Avatar
I was spraying a 150 from 2800rpm till 6psi. It was a little much for my suspension setup though.
Old 09-27-2008, 01:09 PM
ctx97's Avatar
I'm considering running nitrous when I get my turbo build together. I was thinking about making my purge valve dual purpose as a intercooler sprayer.
Anyone done this?
Old 09-28-2008, 02:11 AM
BoostnTBSS's Avatar
we have spray a 30-70 shot on a GN motor only on the trans brake and it builds boost fast..
Quick Reply: Nitrous On a Turbo car
