Turbo Timer Install
Old 09-28-2008, 11:51 AM
nasty_ss's Avatar
Default Turbo Timer Install
So I have a 99 Turbo SS and it's not a rear mount kit. I need to find out how to install a turbo timer. More importantly I need wiring diagrams because I have no clue.
Old 11-11-2008, 05:04 PM
rudyzturbota's Avatar
i to would like to install one, anyone ever done this yet
Old 11-11-2008, 06:03 PM
Sluggish's Avatar
What is the real purpose, the only cars I have seen use them in this area were my friends 2 Srt4s and an Evo. None of the turbo mustangs do.
Old 11-11-2008, 06:04 PM
Reject's Avatar
i dont use one either, i just drive the last few miles calm like. i searched about them and found out most of the guys here dont use one either
Old 11-11-2008, 06:10 PM
Monello's Avatar
The real purpose is to allow the turbo/oil/car to cool down a bit after driving hard.
The worst thing for a turbo car after driving hard is to pull into a garage and turn it off right away.
The turbo timer allows the car to stay on for a certain amount of time without the key in the ignition. Think of it like a remote start, but its a remote turn off.
Old 11-14-2008, 12:28 AM
exactly does any one ever installed one on a f-body? wonder if you can just reverse that remote start up? any idea's???
Old 11-14-2008, 02:49 AM
rx_treme's Avatar
i've always had them in all my rx7's. They're completely annoying. Most of us care about our motors as it is and wouldnt haul *** then just turn the car off, or maybe im just used to driving turbo cars.
Old 05-18-2009, 12:33 AM
nasty_ss's Avatar
coming back to this topic to see if anyone has done it yet. ttt i'm still searching posts just in case someone else has
Old 05-18-2009, 01:27 AM
specsbrat's Avatar
http://forums.turbobricks.com/showthread.php?t=7976
hope this is what your looking for i googled it
Old 05-18-2009, 05:12 AM
stevieturbo's Avatar
Best place to install them is in the bin...what a load of ricer gimmick.
If you abuse your car just before shutting it off...you really dont deserve it. It isnt difficult to cruise for a minute or two before shutting down.
Old 05-18-2009, 07:40 AM
TNTramair's Avatar
+1....I dont have one...dont think i need it. just letting it idle for a few seconds or even cruise around easy for a minute or 2 should be sufficient enough.
besides, with the VATS system in the car, you need the signal from the key to keep the car running which means you'll have to rig up another key under the dash somewhere so the VATS reads it. same thing you'd do with a remote start basically. its really useless unless you're completetly impatient and cant wait in the car a minute or so for it to cool down. just my .2 cents.
Old 05-18-2009, 10:41 AM
Monello's Avatar
I beleive you only need the vats for startup. So if its already on you should be ok.
Old 05-18-2009, 11:09 AM
3800SII's Avatar
May I add that this is actually a good thing for rear mounts. Here is the guide that I used:
http://khturbo.net/faq/FAQ.html
I could not find any other way to add it to my F-body becasue of the VATS.
Old 05-18-2009, 11:27 PM
nasty_ss's Avatar
i don't it's not my first turbo car. i just thought it be nice to have.
Old 05-19-2009, 06:46 AM
TNTramair's Avatar
oh ok....its possible...im not too familier with how that system functions as a whole.
Old 05-23-2009, 11:16 PM
NightHawk's Avatar
VATS is actually a fairly rudimentary security system, it's very easy to bypass...anyone, like myself, who has done a remote start has done so. It works via reading a chip in the key which simply provides the circuit with a given resistance. Once the circuit sees that resistance, you're good to go. A GM dealership should have a VATS reader that they plug your key into and can tell you the resistance it reads.
I'd be inclined to agree, though, that VATS is a startup ordeal and continuing to run the vehicle after the ignition has been shut off shouldn't be affected by it.
Quick Reply: Turbo Timer Install
