tial 44 wastegate to small?
Old 09-30-2008, 01:32 PM
one fast zo6's Avatar
Default tial 44 wastegate to small?
hi i have a 408ci motor on 15 pounds of boost from a gt88 turbo thats front mount. is the tial wastegate big enuff for 850rwp????? if not what wastegate do i need, thanx thomas
Old 09-30-2008, 01:42 PM
LS1Tech Sponsor
hellbents10's Avatar
Yes it will be big enough to make the power you want, but depending on pluming, placement and turbine housing you may have trouble with boost control at lower levels.
Old 09-30-2008, 01:58 PM
where sould the wastegate be mounted on the hot side/ where From the turbo flange thanx thomas
Old 09-30-2008, 02:03 PM
LS1Tech Sponsor
You want a smooth transition into the gate from both banks if possible. Closer to the turbine housing is good.
