Comp. Ratio for this boost application...
Old 09-30-2008, 04:38 PM
Bucktooth's Avatar
Default Comp. Ratio for this boost application...
What compression would you run.
I am going to build a 408 to run NA until i can run boost. I want to run up to 20-22 lbs of boost when all said and done. I plan on running on E80/E85. What compression would you build the motor for 9.0?
Old 09-30-2008, 05:30 PM
rubbersdown's Avatar
If I were building it and planning to run that much boost i would run a 8.5cr
Old 09-30-2008, 08:47 PM
EPP
EPP's Avatar
Turbo or supercharger? This will make a difference in what you want to have the compression ratio at. Bob
Old 09-30-2008, 09:06 PM
nahasapeemapetalon's Avatar
Twin turbos.
Old 09-30-2008, 10:43 PM
Bucktooth's Avatar
Originally Posted by nahasapeemapetalon
Twin turbos.
Haha, we will see. Turbo though for sure. It matters?
Old 09-30-2008, 11:06 PM
MY99TAWS6's Avatar
9.0 would be pretty good I think especially on e85 stuff is the HOTNESS for boosted engines!! Could likely even go 9.5 on e85. 8.5 seems more for pump gas and bigger boost. I went 9.5 but don't plan on much past 15psi.
Old 10-01-2008, 01:45 AM
Tom@SpeedInc's Avatar
i'm running 10:1, great driveability
Old 10-01-2008, 07:39 AM
Bucktooth's Avatar
Originally Posted by Fraser@SpeedInc
9.5:1
You think i could run 20 lbs with E-80 with 9.5 comp ratio?
Old 10-01-2008, 08:16 AM
Dumb Ass Vette Moderator
ls1290's Avatar
With the right tune and setup, sure
Old 10-02-2008, 03:11 PM
Bucktooth's Avatar
9.5:1
Is that at 7lbs though?
Old 10-02-2008, 04:16 PM
camaroandreas's Avatar
I´m running 30-35 psi with 9.8 cr with E85. No problems at all...
Old 10-02-2008, 05:24 PM
jason02Z's Avatar
10.5 should be good..my forged motor will be a round 10.5 or a lil more and on e85. is this going to be a street car or for racing?
Old 10-02-2008, 06:17 PM
BoostnTBSS's Avatar
10.0-10.5 will be good.. but why stress on a boost level like 22 psi its just a number i will do the math for my set upi beleive it was 9.5-1 with 72 cc heads and i went with 64cc heads and spoling was not a prob just got to tune it right and take your time
Old 10-02-2008, 06:59 PM
Bucktooth's Avatar
I just want to maximize power with boost.
Old 10-02-2008, 07:00 PM
Bucktooth's Avatar
Really? Whats your setup???
