Dynoed 1170hp/1180ft/lbs today.
Old 10-01-2008, 09:48 AM
camaroandreas's Avatar
Default Dynoed 1170hp/1180ft/lbs today.
I dynoed my 6.0 in a superflow sf-902 engine dyno today.
6.0
9.8cr
E85
S480 1.32/ar turbo
And it made 1170hp/1180ft/lbs at 30-20 psi (dropping on high rpm to loose wastegate springs). And to small intercooler (194 intake temp).
Backpressure is 1:1 compared to boost
But a problem: I couldnīt rev over 6800 rpm, sounds like valvefloat or lifterfloat. I use PRC dual springs kit and LS7 lifters.
What do you think my problem is? I need to rev 7500 rpm.
Old 10-01-2008, 10:03 AM
7 Second Club
Phil99vette's Avatar
Nice! You need more spring pressure.
Old 10-01-2008, 10:20 AM
So its not the lifters?
Can i shim it or is there a better valve spring kit to buy somewhere?
Thanks,
Old 10-01-2008, 10:30 AM
LS1TECH Sponsor
DrTurbo's Avatar
Not bad.......that turbo will do around 1200-1250 max. We are working on the new Billet 82mm version of that turbo. Should have it ready soon......its rated at 127lbs/min. Upgrade to the 80mm ETT.
Also like Phil said...spring pressure might need to go up.
Old 10-01-2008, 10:47 AM
Rickys S/C Z28's Avatar
wow man id give anything for that kind power!!!!
Old 10-01-2008, 11:19 AM
lt170chevelle's Avatar
nice man
Old 10-01-2008, 11:46 AM
Black_Hawk_02's Avatar
i wouldnt know what to do with 1200 at the wheels... lol
Nice job and good luck!
Old 10-01-2008, 11:47 AM
MonkeyBoneSS's Avatar
How about some more details about your set-up. Maybe even some photos!!!! Nice numbers btw
Old 10-01-2008, 11:52 AM
LS1TECH Sponsor
DrTurbo's Avatar
Those are Flywheel #'s, NOT rwhp. Rwhp is about ~850-900 depending on tranny and convertor slip.
Old 10-01-2008, 11:55 AM
BLNLS1/RX7's Avatar
Very impressive.Could you please post the dyno sheets?
Old 10-01-2008, 12:04 PM
valiant65's Avatar
Wow! And all that with bunch of stock parts!!! Almost 1600Nm ! Congrats!
Old 10-01-2008, 12:05 PM
Mekkadon's Avatar
damn, did you run into head lifting problems? I figure you would @ 30PSI...
Old 10-01-2008, 12:23 PM
I donīt run mls gaskets. I have done what we do on all euro engines to make the head seal. We mill down a ring around the cylinder with a cutting edge that cuts into the head. Also known as "pyramid rings" and "fire rings". Then you can boost as much as you want
Some pics:
I think itīs good with stock block/crank/853 heads
Old 10-01-2008, 12:25 PM
1601 nm
We also boosted 35 psi at 3600 rpm one time, but i thought it was overkill for my stock crank
Old 10-01-2008, 01:44 PM
Reject's Avatar
VERY nice but you know i'm going to ask this so might as well get it over with.....where's the vid?! lol
i really like how you did all that with "normal" off the shelf parts
Old 10-01-2008, 01:54 PM
sciff5's Avatar
I've never heard of this. You would think if it was that easy most people would do it
So what gasket do you run?
Also I'm surprised it took 30psi to get those numbers out of a 6.0L, I'm even more surprised it stayed together doing so.
Dynographs and vid coming tomorrow!
Old 10-01-2008, 01:58 PM
abbaskhan's Avatar
congrats
Old 10-01-2008, 02:05 PM
Itīs not easy, it takes much development. I make these gaskets every week.
We also sell this type of gaskets to BMW,Volvo and now LS1
We also made this type of European fastest 4 cyl car, 7.20@190mph.
Old 10-01-2008, 06:14 PM
Reject's Avatar
i know to o-ring the blocks is pretty expensive
Quick Reply: Dynoed 1170hp/1180ft/lbs today.
