Best valve spring kit?
Is there any valve spring kit with more seat load then the PRC kit?
Itīs not good enough for my 30 psi and 7500 rpm.
Thanks for help.
/Andreas
Thanks for help.
/Andreas
If not, do you know the seat pressure prc kit have?
patriot extreme's are 160lbs on the seat at of seat pressure at 1.8" installed hight. I have mine shimmed to 180lbs on the seat. I believe the PRC's are 140 or 145LBS of seat pressure at 1.8" installed hight.
