Vendors for tubing/flanges for turbo build
Old 10-05-2008, 12:08 AM
trey04gto's Avatar
Default Vendors for tubing/flanges for turbo build
Looking for a "builder kit" of 3.5" mandrel bent 16ga mild steel tubing
Old 10-05-2008, 01:33 AM
Fast_94_Z's Avatar
check out modular turbo he will give you a nice deal.
Old 10-08-2008, 12:20 AM
trey04gto's Avatar
Checked out modular, apparently 3.5" mandrel bent mild tubing is hard to come by... Anything else
Old 10-08-2008, 01:37 PM
ModularTurbo's Avatar
call me back I can get it now.
Old 10-08-2008, 02:34 PM
v8bug's Avatar
Summitracing sells 3.5" mild steel 180 degree bends, both 18g and 16g, not cheap, but they are quite nice
http://store.summitracing.com/egnsea...115+4294864604
they also sell straight 3.5 in 4' sections
Thats what I am making my downpipe out of
Old 10-08-2008, 03:26 PM
LS1TECH Sponsor
DrTurbo's Avatar
Racepartsolutions.com
Old 10-08-2008, 08:39 PM
blazin's Avatar
Ebay item No: 250306070115
Old 10-08-2008, 09:12 PM
Turbo Tech's Avatar
TTI we've got everything in stock from 1.50 to 5.00, also most flanges cnc or flame cut. www.turbotechnologyinc.com
Old 10-08-2008, 10:56 PM
trey04gto's Avatar
This was almost too good to be true!!! But... Aluminized steel
Old 10-08-2008, 11:05 PM
trey04gto's Avatar
You do want only Mild steel for a downpipe correct? Do I have bad info?
Old 10-09-2008, 08:33 AM
BlackSuperchargedLS1's Avatar
Aluminized steel is used for exhaust, so you can use it for your downpipe (I am using it for my hotside). If you use mild steel, then you really need to get it coated. Do a search for aluminized steel and you will find comparison threads with more info.
FWIW I got all my tubing from http://store.racing-solutions.org/
Old 10-09-2008, 08:41 AM
RAACCR's Avatar
Agreed
Old 10-09-2008, 12:10 PM
trey04gto's Avatar
I plan on coating the downpipe anyway so aluminized steel can still be coated?
LS1TECH Sponsor
DrTurbo's Avatar
Yup...sure can.
