Stock bottom end LQ4 goes 5.72@126 1/8th
Old 10-05-2008, 11:05 AM
Frank02L's Avatar
Default Stock bottom end LQ4 goes 5.72@126 1/8th
Had to put another set of rods and pistons in the motor from a friends core motor (he's building a 408) after lifting the heads a little and getting some coolant in the chambers bending the rods that came in the '05 motor. We yama-bonded the heads and put about 6-8more ftlbs of torque on the L19 studs. The basic combo:
'05 LQ4 with '02 LQ4 rods/pistons (all we did was slap them in)
as cast L92 heads with stock L92 valves
PRC spring/retainer/pushrods from Texas Speed
GM L92 carb/efi intake
GT47-88 turbo by Precision
PT1800 a/w intercooler
PTC Converter/Glide
9" rear
calvert split leafs and caltracs
325/50 MT ET Street Radials
Its in a '00 Isuzu Hombre (S10 with different nose skin, actually in Brazil this is what the S10s all look like) and it was 3280-3290lbs last night depending on how much ice we had crammed into it.
Now the results...
As in the topic it went 5.72@126 at 3280lbs, with a 1.33 60'. Next pass had the bye round and went 1.29 60' but had to shift when the front end was coming down and unloaded the tires and slowed to a 5.79@124 Then in the finals something was hurt again. We were the only car to get down the track in qualifying and ended up being #1Q. All the other cars in the class were 632" big blocks with a few healthy doses of n2o. The record holder (at 5.18) went a best of the night 5.38 in the finals.
Old 10-05-2008, 11:09 AM
lt170chevelle's Avatar
damn thats bookin!! nice job...any pics or vids of it?
Old 10-05-2008, 11:26 AM
nick97ta's Avatar
You guys are getting that truck moving!! sorry to hear you guys hurt something again.
Old 10-05-2008, 12:15 PM
tomz28's Avatar
PICS
that is badass
Old 10-05-2008, 12:46 PM
Frank02L's Avatar
We got in truck vids but I'm not smart enough to transfer them from the camcorder to the computer.
lots of pics here, build and racing pics
Old 10-05-2008, 01:40 PM
LS1Tech Sponsor
hellbents10's Avatar
Wow, that is really impressive, cool truck!
Old 10-05-2008, 01:57 PM
camarols1's Avatar
I love this build !!! Keep it coming Frank!!!
+1 for a video of the Hombre at work eating Big Blocks!!!!!
Old 10-05-2008, 02:24 PM
zssman's Avatar
Frank, u guys bringing it to memphis this coming weekend?
Old 10-05-2008, 03:59 PM
Frank02L's Avatar
Nope. My little girl's 1st bday party is saturday. And we're going to have to "rebuild" it again I am afraid. We are planning on coming over sunday though. Phil I sent you a PM on LRRS
Old 10-05-2008, 08:19 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Very nice!
How much boost?
Old 10-05-2008, 08:21 PM
Frank02L's Avatar
18psi
Old 10-05-2008, 08:56 PM
jleews6's Avatar
Very impressive. What cam is in it?
Old 10-06-2008, 09:48 PM
B18B1LS1's Avatar
Thats amazing! You should be in the 900 rwhp range to turn those times at that weight. Surely that ET is some kind of stock bottom end record??
Old 10-07-2008, 07:11 AM
LS1Tech Sponsor
I would think so too, that is some major power. It took all of 875+rwhp@20+psi to get the 4000lb GTO to go 140 the other day, to bad it was with 11.6 et lol.
I love those S-trucks.
Old 10-07-2008, 07:19 AM
Frank02L's Avatar
Its got a Crane camshaft in it. 236/240 600/600 112. If its not a record I want to know how the person with the record keeps from bending the rods. LOL. No detonation signs on the plugs.
Old 10-07-2008, 09:09 AM
LS1Tech Sponsor
I think we are close to the same level, although the Lq9 rods are better then the Lq4 rods. Also the Ls2 rods are nice, both Ls2, Lq9 and the all of the newer truck engines got the good rods with floating pistons.
Old 10-07-2008, 09:35 AM
Frank02L's Avatar
Yeah the motor was originally an '05, but we stuck '02 pistons and rods in it. The '02s definitely appeared weaker. But the pistons looked identical (both floaters). I think the first set bent because the heads were lifting, because we'd get a few oz's of h2o out of the catch can after the passes. This time we got a few trickles each pass. But we yama-bonded the heads and the torque wrench was about 6-8ft lbs low. Before this weekend our best mph was 122 and it ran 119s early in the year in good air. I'm as tickled with the 1.29 60' on the radials as anything else. Shame that run didn't pan out as well. If we could get all of our best incrementals down, I think the truck would go 50s.
Old 10-07-2008, 10:27 AM
1INSANEGTO's Avatar
PTC Converter/Glide
9" rear
Now the results...
Wow good to here and gives me hope for my project. I will be starting on the 67 Camaro TT5 car and its about 2600lbs. I just wanna use a stock long block with upgrade springs and good cam. A 106mm turbo and running E85.
Old 10-07-2008, 10:43 AM
Frank02L's Avatar
TT5? Even at 2600 I can't see being competitive with a stock motor. We're not competitive in Radial stuff. We're fine for the first 60'-100' but after that we can't make enough power to keep up. Good luck thought sounds like a fun thing to try
Old 10-07-2008, 12:05 PM
LS1Tech Sponsor
The radial vehicles are getting out of control, you need almost 2000hp to be competitive over 3000lbs lol.
Quick Reply: Stock bottom end LQ4 goes 5.72@126 1/8th
