PTK Downpipe
PTK Downpipe
My new turbo has a 3.5" outlet and with the v band its 4.5". Does anyone have a PTK downpipe that would fit or could make one for a price? I really don't want to go to a shop around here to have them make one. Hopefully someone on here has one or could fab one up to fit to the 3" exhaust supplied with the kit.
You would go by the ID which is 3.5" You can get 3.5" pipe but its kinda hard to find. I would reccomend a 4" DP if it will clear, there are places that sell reducer cones to go from 3.5 to 4", infact I ordered one for myself today. You can also get just 1 side of a 3.5" V-band flange since the other side is made on the exhaust housing.
http://store.racing-solutions.org/tr3to3.html
Well, I am using an old diesel Lincoln sa-250 pipeline stick machine but you can run a tig torch on any DC stick machine, you just have to run it electrode negative and get a bottle of 100% argon. I have to scratch start just like stick welding and have no foot pedal, it really forces you to become a better welder the hard way, lol. I'm about to get an AC/DC machine with pulse, High frquency, & a foot pedal, man it will be so nice!
http://www.racepartsolutions.com/pro...sembly&cat=106
I'm going to certainly try it. Not adding to it to make it larger, cut away from it to compensate for the extra material to allow for the reducer.
Edit: Aren't the 70mm and 76mm turbo's the same size, just the internals are different?
If the downpipe is made into a 3.5" then it will stick out .25" more and reduce to the 3" when it's straight. So I'd need a 90 degree 3.5" piece of 321 ss a 4.5" v band clamp, and the reducer. I smell all kinds of bullshit. And I'll probably need a BFH.
