Fuel rail issue
Old 11-18-2008, 09:54 AM
maxgee's Avatar
Default Fuel rail issue
I did some search and can't a answer to the problem, although I think I found the problem.
The last injector on the driver's side is leaking b/c the back of the rail is not fitting snug on top of it. There gap from the rail when bolted down is too big and the o ring is visible. The fuel rail is stock and the injectors are Ford Cobra 42s. Appears if I bend the rail down some, problem should be fixed. Any ideas?
Old 11-19-2008, 02:20 PM
maxgee's Avatar
Well I took the rail off, put on new o rings and switched them around and the same issue: the driver side rear gaps out about 1/4inch after I drive the car around.
