L92 427 injector help
Will the 42LB Bosch Design 3 Injectors be sufficient for my L92 427 build? Its going to be pure N/A, FAST 92, TFS 235 heads, 235x/26x cam, 1 7/8' headers, etc., ~575 rwhp motor. Planning on retaining stock fuel rails and fuel pump if possible.
Fuel pump no way stock pump is good for 400-430 max. You will need to upgrade to a 255 pump and 42# injectors will be just barely OK if you ever plan on a little more power you will need larger injectors so 60# will give you some breathing room.
Nate
Nate
