Running Out Of Injector. Come Inside
I am running out of injector and cant figure out why. I am only at 600rwhp and 60lb Mototrons, Dual intank Walbro255s (wired together), return style fuel system with Boost Referenced Regulator. I am at 130% injector duty cycle at 6k rpms. AFR is 11.5 across the board. FP is 55psi Idle and around 70 WOT.
Thanks
Thanks
I am running out of injector and cant figure out why. I am only at 600rwhp and 60lb Mototrons, Dual intank Walbro255s (wired together), return style fuel system with Boost Referenced Regulator. I am at 130% injector duty cycle at 6k rpms. Anyone know why? Any help appreciated.
Thanks
Thanks
If everything is as it should be you should be seeing around an 85-90% duty cycle.
Maybe you have more power than you think.
Same problem..
Thanks
Thanks
Might get better, more feedback, if the details were all in 1 post??
https://ls1tech.com/forums/pcm-diagn...og-inside.html
as you posted in another forum??
I posted into the pcm forum, because I wanted my log and tune looked over to make sure they looked ok. I didnt want to post the tune and log over here in the fueling forum..
