What fuel system to support 800+rwhp s/c DD?
Old 12-25-2008, 01:09 PM
jeremym's Avatar
Default What fuel system to support 800+rwhp s/c DD?
What fuel system would I need to support 800+rwhp F1A 427 LS7 daily driver. Like what brand,size high imp. injectors do I need? Do I really need fuel rails, new fuel lines? What tank pumps do I need?. I was looking at Racetronix 79lb High Imp. injectors, anybody know about these injectors. Thanks for any info
Old 12-25-2008, 01:16 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
For your power level, you should consider a complete system, including all lines.
Give me a call when you get a chance. I have a complete fuel system to suit your needs, that includes: filter, fittings, lines, rails regulator, and dual intank pumps with plug-n-play wiring harness.
Old 12-26-2008, 05:17 PM
Pinky93's Avatar
Not to hijack, but would be interested in a fuel system for a 2000 Trans Am that I am going to do an APS Twin Turbo system on. They suggest an MSD booster, but that doesn't really make me feel safe.
Old 12-26-2008, 05:43 PM
LS1TECH Sponsor
I have complete kits for your car as well.....
Old 12-29-2008, 06:09 AM
jeremym's Avatar
Thanks I will call.
Old 12-29-2008, 06:10 AM
jeremym's Avatar
Anybody else?
Old 12-29-2008, 06:18 AM
cjg454ss's Avatar
Originally Posted by jeremym
Anybody else?
im running a 88mm turbo, my system consists of 60lb injectors that are maxed. -8 feed line, stock feed used as return. aeromotive regulator boost referenced. i built my setup. i ran stock fuel rails for a short time but would lose fuel pressure when the boost would come in. id say 600rwhp or so and a single walbro. it does ad up for all the parts youll need. i went with all summit brand braded lines and fittings. 450.00 worth, 89.99 for the -8 line. 200.00 in fuel pumps. then 200.00 for fuel rails, 250.00 for the proseries regulator. that was about as budget as you can get running a new feed line. a local guy here has some good power, 76gts turbo and he is running the stock lines. id says hes in the 750rwhp range and said he pushed stock lines to 1000rwhp. that was using the evap as a return line. hope this helps.
chris
Old 12-29-2008, 10:39 AM
Nasty N8's Avatar
As Lonnie pointed out you are at a level you need at least twin pumps and new feed and return lines. Lonnies and our kits are as complete and reliable as you can get.
Nate
Old 12-29-2008, 11:07 AM
cjg454ss's Avatar
Nate
stock lines will work, only problems are the fittings are 35 bucks a piece. it is not much more $ to get a new feed line.
$70.00 (2 fittings) vs $89.99 (20ft fuel line)
Old 12-29-2008, 12:25 PM
Nasty N8's Avatar
Yes you are correct.
Old 12-29-2008, 12:35 PM
cjg454ss's Avatar
If you want a complete setup with everything you need go with Lonnies or Nasty nate. You can not go wrong with these guys, ive spoke with both, very knowledgable, stand up guys. You wont save much more piecing it out yourself. Summit cannot match the customer service they will provide either. hope this helps
chris
Old 12-29-2008, 06:30 PM
tha joker's Avatar
I have a lonnies kit and one of my herd has the nasty setup.both are great but i am partial to lonnies after recieving it,PLUS you cant beat his service AFTER the sale.....
Old 12-29-2008, 06:52 PM
mygto's Avatar
Pm sent Nasty.
Tim
Old 12-31-2008, 07:02 AM
jeremym's Avatar
do I really need to change fuel lines, and fuel rails? Or could I just use 79lb's and twin tank pumps?
Old 12-31-2008, 08:39 AM
Coal Mining Director
onfire's Avatar
You might "get by" that way but why risk a nice engine for a few more dollars...
Old 01-01-2009, 01:08 AM
LS1TECH Sponsor
You will likely need lines before you need 79lb. injectors.
Give me a call & I'll be glad to help you out.
Old 01-02-2009, 03:43 PM
RooRnZ28's Avatar
i'm in this boat as well.....pm sent to nasty n8
Old 02-02-2009, 03:50 PM
9 Sec. Club!!!
dan03mach's Avatar
Jeremy just change out the line, rails fitting, etc. just like the setup I have at the house i showed you. Then you won't ever have to worry about it. Do it right the first time.
