The difference between a high PRESSURE vs. a high VOLUME pump.
Old 12-28-2008, 12:43 AM
charlie c5's Avatar
Default The difference between a high PRESSURE vs. a high VOLUME pump.
I just installed a new Walbro 225 fuel pump in my 02 turbo Trans Am WS6. the pressure at idle and when crusing is a steady 57 lbs. But drops to about 35 when I get on it. I guess I need to add a 2nd pump. But when I called the local shop they asked if I want the high PRESSURE or the high VOLUME pump. Whats the difference and about the wiring, cant I just splice into the stock wireing to power the 2nd pump. (the car has 60lbs injectors, and has about 650 RWHP.)
Thanks guys.
Charlie
Old 12-28-2008, 12:50 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
255 is the volume, not sure what they are asking???
They make a lower pressure 255 pump that is rated for the 43# pressure range instead of the 58# that you need.
You are looking for problems trying to run everything off of stock wiring.
If I can interest you in a properly built setup, let me know. The learning curve is steep when you are spending your own money.
