injector help
Old 01-02-2009, 09:39 PM
Big Bird WS6's Avatar
Default injector help
i have a 366ci motor that i am putting a turbo kit on. but i want to break my motor and my trany and my rear end in all at the same time.
what size of injectors do i need just to run the motor N/A
it is a 366ci, 9.5:1 ratio, 225 AFR heads, 228/228 on a 115 LSA, ls6 intake, that is about it. if you need more info let me know.
thanks
Big Bird
Old 01-02-2009, 09:42 PM
or will like stock LS1 ones work for now? just for break in. no hard hits?
or ls6 ones
Old 01-02-2009, 11:34 PM
405HP_Z06's Avatar
If your just going to putt around enough to break in the parts, stock injectors would be fine.
Old 01-03-2009, 07:57 AM
well i wont lie. i would say putt around till i got like 500 miles on the stuff. then give it hell a few times before the turbo goes on.
Old 01-03-2009, 08:02 AM
FICINJECTORS's Avatar
hrm, send me a PM, I may be able to work with you on something to get you going on both fronts.
