ls1 fuel pressure questions
Old 01-02-2009, 11:53 PM
gobigorgohome's Avatar
Default ls1 fuel pressure questions
i know this has probably been covered but i couldnt find an exact answer, what should my fuel pressure be set at on my ls1 (out of 99 camaro)with aeromotive regulator stock injectors, heads, pistons, compression 11.25 to 1 bla bla, i have a guage right after the regulator in my fuel system showing about 50psi at the momentwith engine at idle. should i be checking at full power should i be checking at the rail instead, any info would help
Old 01-03-2009, 06:23 AM
AFASTYZFR1's Avatar
with the regulator unhooked from vac source fuel pressure should be 58 psi
Old 01-03-2009, 07:50 AM
FICINJECTORS's Avatar
yup!!
Old 01-03-2009, 12:03 PM
my regulator is near my fuel cell with no vaccum hooked to it,
Old 01-07-2009, 03:31 PM
ultraz's Avatar
whats the range for a fuel gauge off the stock rail? will it ever exceed 60psi?
