Svo 30lb injectors on a stock engine?
Old 01-03-2009, 12:04 AM
97ramsst's Avatar
Default Svo 30lb injectors on a stock engine?
Will these #30 SVO injectors work fine as basicaly stock replacments units on my 02 WS6? I dont want to go through the trouble of getting the car tuned (its a SHOW car that I may put 100 miles a year on!) so if they wont work with the stock tune/stock fuel pump/stock fuel rail than I am not going to get them.
http://cgi.ebay.com/ebaymotors/SVO-F...Q5fAccessories
For what its worth I like them because they are red and will match the MSD coils I am putting on...performance is a non-issue with the car as long as it will run at least as good as stock with them.
Also is that the cheapest place to get them???
Old 01-03-2009, 12:30 AM
405HP_Z06's Avatar
These injectors will require a PCM tune to work correctly.
Old 01-03-2009, 12:32 AM
97ramsst's Avatar
Ok...thanks, I will just put the stock ones back in then!
