need help car will not start
hi, it started a week ago. car would start right up and when you turned it off the car would not re-start. wait 10 minutes and it would start right up. well today it would not start. so i replaced the fuel filter and still no start. i can hear the fuel pump priming. i had my brother turn the key to on and i was up front by the fuse and relay blocks and you can hear the relays click and then you hear a arking sound that sounds like its coming from the abs block. its like the car is getting zero fuel or zero sprk. i bought some carb spray and i am going to spray it into the throttle body tomorrow and see if it trys to fire. what i don't like is the arking sound i hear when you turn the key on.i also switched the relays around to see if it would start. if it turns out to be the fuel pump what do you reccomend??? any info would be appreciated. thanks
