Injector install, fuel rail disconnect Y/N?
Old 01-14-2009, 10:44 PM
01Wickedwench's Avatar
Default Injector install, fuel rail disconnect Y/N?
Got the injectors, dyno time comming up on re-tune time, it looks like i can do it without disconnecting the fuel rail. Anyone install injectors without disconnecting the fuel rail?
Old 01-14-2009, 11:11 PM
405HP_Z06's Avatar
I've done it on a C5 but not an F-body. So, I would assume it can be done if you have room to rotate it to the side. Make sure you bleed off the fuel pressure before you remove the rail.
