Racetronix Fuel Pump......
Old 01-20-2009, 07:35 PM
ALLMOTOR346CI's Avatar
Angry Racetronix Fuel Pump......
Ok here's the deal me and my father both run the racetronix fuel pumps but the problem is he get's WAY more fuel pressure then i do.....His car at idle put's out 60-62psi now my car at idle only puts out about 54-56psi and at WOT he's at about 56psi-58psi and mine under WOT drops down to about 48-49psi.....Is there anyway of testing the pump or checking anything to solve this problem i just dont like the low pressure when im spraying the car and would rather try a quik check/fix instead......
Thanks in advance......
Old 01-20-2009, 07:57 PM
98Camarod's Avatar
To fix it you could run a vacuum referenced regulator.
Old 01-20-2009, 07:59 PM
Thanks ill look into that.......
Anybody else have anything?!?!?!
rarelyseen's Avatar
did you get the new sending unit?
Old 01-20-2009, 08:05 PM
Nope but i did try my fathers sending unit and i still got about 54psi @ idle.....
Old 01-20-2009, 08:58 PM
koolaid_kid's Avatar
Perhaps a silly question, but are you both running the Racetronix (or similar) harness? Yours sounds like a voltage/current drop at WOT, which is what I would check next.
Old 01-20-2009, 09:02 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
i you tried your fathers sender, it also contains the fuel pressure regulator.
This should make your car flow the same as his.
In this case, you either have a voltage problem or your gauge is not correct.
Keep this in mind as gauges are not as accurate as people often think they are.
Old 01-20-2009, 11:11 PM
I'll look into that as well i might just say f*ck it and get a new pump......
And LonniesPerformance i already switched gauges with my fathers gauge and still got the same 56psi @ idle......
Old 01-21-2009, 03:04 PM
LS1TECH Sponsor
Somtehing does not add up.... you change fuel buckets with another car, so in essence you swapped the regulator & pump together.
The only thing left is voltage or the gauge.
Did you check voltage at the pump?
If you swapped gauges, was it electronic & did you also swap the sender?
Old 01-21-2009, 05:22 PM
Swapped the sender and gauges and as for the voltage to the pump deal i will be doin that this week......
