Fuel regulator Which one works well?
I'm using After market Fuel Rails (Areomotive), on a LS1,(in 69 camaro w DSE Tank) has anyone used the Areomotive fuel regualtor ? also is it best to buy one that has a Fuel return, and plumb the return from the rail into that, then to the tank ?
Rascalsrods,
Call Aeromotive. Talk to Brett in the tech department. He's awesome to work with and will get you lined out with everything needed to finish your system. I don't like mis-matching components from different company's so I would just stick with Aeromotive, besides they are the best!
C5Fire, thanks for the advice, I called Brett, really helpful !Took time to explain everyhting needed & why, return vs. non, nitrous hook-ups, examined my fuel pump out put for the applicatione, etc, I'm sold on Aeromotive !
