Quick Hose end question
Old 02-03-2009, 11:31 AM
v8bug's Avatar
Default Quick Hose end question
I am going to re-doing my fuel system the right way now that I have added a turbo and bigger injectors.
My question regards the use of hose ends such as this
http://store.summitracing.com/partde...0&autoview=sku
I have never used fittings such as this, only barb fittings and lots of hose clamps. So how exactly do these fittings seal against 50+psi of fuel pressure?
Do you just insert the hose in the fitting and its done?
I will be using all braided stainless hose's also
sorry this is probibly a dumb question
thanks,
Matt
Old 02-03-2009, 12:28 PM
mebuildit's Avatar
Call XRP. They have the best hoses in my opinion. You never get a snagged hand cut or burn yourself in the braided lines. You will love these when you see them. The ID is larger and flows more that a standard braided line.
Good luck with your hose.
Old 02-03-2009, 08:08 PM
pmbmax's Avatar
thanks,
Matt
First take the fitting apart .(it unscrews) put the hose in the outer part , then put anti seize on the threads and screw them together .If you are going to do a system order the aluminum jaws fron jegs or summit to hould them in a vice because it gets hard to turn befor it bottoms out .
Old 02-10-2009, 02:41 PM
MIGHTYMOUSE's Avatar
the answer is that the hose is compressed between the inside and outside of the two fitting pieces when they are screwed together. they can hold much more than 50psi
