160lb injectors and a injector driver box
Old 02-04-2009, 04:03 PM
ALTRDTA's Avatar
Default 160lb injectors and a injector driver box
I read somewhere that you are not supposed to use an AEM injector driver box with 160lb injectors (something to do with the ohms.) I currently have both the AEM injector driver box and 8 160lb injectors... I will be running E85/E98 through these injectors and then for pump gas if I have to resort to that I have a set of 96lb injectors. I just wanna make sure before I install this AEM IDB that it's going to be couture. Either way I am going to have to run this aem box or a resistor for the injectors. Let me know your thoughts! Thanks in advance...
Old 02-05-2009, 10:25 AM
Nasty N8's Avatar
Not sure on the AEM box but we have run 160 inj with the VersaFueler. But if you need to control that much fuel I would rec. a complete fuel system controler like a BigStuff.
Nate
Old 02-05-2009, 04:52 PM
ALTRDTA's Avatar
I'll be running a AEM EMS. It's on order and should be here mid this month. I know nobody around these parts runs em that much. But my bro has had extremely good luck with them as well as the supra boys... I don't see why they aren't used much. Plug and play and nearly as much parameters that can be changed as any other EMS....Ohh did I mention a 1/3 the price?
Thanks for your advice. You're a great help!
Old 02-15-2009, 02:24 PM
Sandmann120's Avatar
Any news on this?
