Need help with fuel cell
I am having a fuel cell installed in the trunk of the ctsv, however i would like to retain the stock fuel level gauge on the dash. What would i need to do to make it functional again. Thanks in advance.
you need a gm sending unit. the f bod guages require an odd ball ohm sending unit. not a typical 0 to 90. I would first find out what ohm you're factory guages requires.
