Vic Jr guys, what do you do with the cannister purge valve?
Here is what I did on my truck. I have run it like this for about 2 years. I used an aluminum vacuum manifold and drilled out a port for the purge and drilled and tapped it for the retaining bolts. The end of the vacuum manifold has a 3/8" fitting that gets plumbed to the back of the intake for its vacuum source. I used tubing from a truck shop for air brakes to connect the Purge canister to the Purge solenoid.
Jeff
Jeff
