what year mustang had the SVO 30# injectors
Old 02-07-2009, 04:43 PM
firebird6786's Avatar
Default what year mustang/ford had the SVO 30# injectors
what year mustang/ford had the 30# SVO injectors and will they work with my lt1 setup?
thanks
Old 02-07-2009, 04:53 PM
FICINJECTORS's Avatar
Originally Posted by firebird6786
what year mustang had the 30# SVO injectors and will they work with my lt1 setup?
thanks
the svo 30 will drop right in your lt1 as long as you use the clips. I don't remember the mustang ever coming with them. They were sold through Ford SVO which later became Ford Racing.
Old 02-07-2009, 06:38 PM
Tom@SpeedInc's Avatar
supercharged Thunderbird 91-95 had red top 30lbs injectors OE
last I checked they've been discontinued, theirs so many other options i've forgot about them.
The white bosch 36lbs injectors are a good alternative and will work in LT1.
Old 02-07-2009, 06:58 PM
405HP_Z06's Avatar
thanks
They never came in a Mustang from Ford.
Fraser is correct, here is the replacement: Design III 30's
Old 02-07-2009, 08:02 PM
blue98Z's Avatar
I've got some Accel yellow top 30# from an LT1 I'm about to put up for sale. PM me if your interested.
Old 02-08-2009, 10:11 AM
ok... thank you for the info.
Old 02-08-2009, 10:12 AM
will these work for a lt1?
Old 02-08-2009, 10:18 AM
405HP_Z06's Avatar
Yes. http://fuelinjectorconnection.com/sh...&productId=188
Old 02-08-2009, 10:58 AM
Originally Posted by 405HP_Z06
ok good. i've searched all over to find what ford car had those injectors... thanks
Old 02-16-2009, 10:05 PM
blackz93's Avatar
That's actually not the replacement. The new ones are red, not orange. Those are just modified to flow 30#, I guess?
Old 02-16-2009, 10:34 PM
405HP_Z06's Avatar
The only difference between the Design III's is the color of the housing and the size holes in the flow plate. You could put a pink with green polka dot case on a Design III with the correct 30 lb/hr flow plate and it would still be a 30 lb/hr injector.
Old 02-17-2009, 08:18 PM
RE AND CHERYL's Avatar
As stated the 30lb units were used in 91-95 SC Thunderbird. 36lb injectors are not used on a OEM application to my knowledge.
Re'
