low fuel pressure at start
I have a 1967 Camaro with a 1998 ls1. It has a Rick's stainless fuel tank with the Corvette return fuel filter. It has #8 an fuel line. I am runing a walbor 255 pump in the tank. When the car is cold it will start fine & have 58 psi of fuel pressure an the rail. If I shut it off & try to restart it the gauge will read 50psi & be hard to start. When I get it running it will have 58psi & seems to run fine. I have not driven it alot lately because of the weather but it has ran fine when I have ben able to drive it. I have replaced the fuel pump & checked the voltage at the pump. It has 13.5 volts at the very least, some times over 14 volts. I have replaced fuel pumps a few times thinking it was a pump issue. I am not sure. Thanks Eric
On 1999 & up vettes there is a single feed fuel line. The extra fuel is bypassed in the filter & sent back to the tank. There is no filter on the return. It does have stock rails.
