98 to 99 Fuel Tank
there is also some issue with the tank in the later model being a plastic unit, where the one in the 98 is a metal ONE piece tank/with filler neck. Swapping the pump is not that bad if you are willing to cut an access hole in the back.
here is a link, I did it pretty quickly and dont think it would be nearly as hard as changing the whole tank. If you are considering it here is a link.
https://ls1tech.com/forums/fueling-i...p-install.html
hope this helps
hope this helps
Ok I Got One More Question. Can I Just Cap Off Where The Sending Unit Goes And Wire Up A New Gauge Wire Old School Style Or Not? Also The Summit Sump Has Two Outlets, Are They Both For The Fuel Lines Or Can I Use One As The Return? And About The 1/2 Vent It Requires I Dont Guess I Follow, Can Someone Help Me With This Issue?
