How do I run Racetronix upgrade harness?
I am trying to run my upgraded Racetronix harness today. I have the new pump installed and this is all I need to do. I have the car up in the air, but there is just no way to get the connectors and harness up around the outside of the fuel tank. How did you guys run the harness around the tank to get up to where the connectors plug into the stock harness?
Ok I went ahead and just routed it through one of the grommets and then ran it under the carpet and up and through my trap door. That seemed to be the easiest. It is all done and the car fired right up. I checked my fuel pressure and now at idle when warm instead of 58 psi I am rocking almost 62 psi. I am guessing this is just because of the bigger pump and the upgraded harness so the pump is getting more voltage right?
I did! You tricked me with another post...
https://ls1tech.com/forums/11231875-post2.html
But yeah, there should be room to push the harness out. Use a coathanger to pull it through if you have to.. But I guess it doesn't matter anymore since you already have the car running again..
