Need help fuel psi drops under accel!
i have a 5.3 with an ls6 cam tuned. Aeromotive regulator and walbro 255lph pump. Plummed all the way with 3/8" push loc, no leaks. Billet rails, ls1 injectors. Fuel filter is new.
My problem is that when i push the throttle, my psi drops way too much. I have it set at around 58-60psi at idle, but it goes as far as 0psi under wot. What should i do now?
I have a 17gal cell none sumped, the pickup is in the tank pulling from the top, maybe i should get a sumped setup? Or something else?
Any help is appreciated!
i have a roll over vent.. does that normally vent until its upside down right? lol i can change my setup to the way your saying... i am thinking of also getting stock rails too.. those billet ones i got have acouple minor accumulations around the fittings of fuel. just cant get those npt fittings to seal up good.
^^Thats right. I had to use quite a bit of thread tape on mine to prevent them from leaking. I'm not sure how the vent works, post up how it works out.
I think the way you have yours set up now is wrong and it works fine at idle, but it bleeds the pressure off when its changed demand.
if this works im gonna go and drink myself retarded... ive had a rough time getting my build on the road...and even came as far as selling it. it has alwasy died or stumbled after i give it throttle... i thought o2's but idk. thanks alot bro. i will post soon.
ive got it all hooked up now, and i cranked the car up. my guage is mounted on the front of the fpr, and it now reads 20psi. i tryed adjusting it both ways with the adjustment screw.. but nothing. is this normal in this setup? before it read 60psi at idle. am i doing something wrong?
i'll put a pic up tomorrow....
Yep...
Is the Walbro in the tank?
The vent valve, if in backwards, will cause the pump to eventually pull a vacuum on the tank, and take the pump out.
The valve is designed to do as you state. Vent when "right side up", close when "on your lid"..
If you are limited to 20psi w/ this layout, I'd look for issues between the rail and the pump pickup.
