are my injectors junk??
Have some used FAST 36lb injectors I want to install but 2 of them have the plastic ring on the injector tip broken inhalf....The O-rings are in great condition.
Will this small plastic broken ring affect anything since the 0-ring still seals tight??
we repair them.. You really need to have that piece as it does 2 things. It holds the oring on the injector and it protects the bottom of the o ring.. If you do not have that on the o ring will dry out and could be sucked off the injector causing a vac leak. We rebuild the whole set for 89.00 including new filters, viton o rings, ultrasonic cleaning, flow tested and new bottom caps.
