Bosch injectors in stock rail?
Old 04-22-2009, 09:42 PM
elevator_idiot's Avatar
Default Bosch injectors in stock rail?
Any problem with doing this. They fit nicely just raise the rail up with spacers and get longer bolts. Haven't pressure tested anything yet but looks like it should work. Anyone else do this. I wanted to use some 30# injectors from another motor instead of the stock ones...
Old 04-22-2009, 10:14 PM
jetlag's Avatar
I had Bosch Design III injectors and also Ford SVO 30 injectors with are a different Bosch design. Both fit fine and needed no spacers...
Old 04-23-2009, 12:25 AM
The injectors I have are Bosch EV1 style and look like these...
They are definitely taller than the stock ones.
Old 04-23-2009, 12:31 PM
jetlag's Avatar
I have those same redtops and bolted them right in. No spacers or anything needed.
But I am assuming you have an F-body? Are you using them on a different vehicle?
Old 04-23-2009, 11:49 PM
Installing them on truck motor 5.3 liter.
