Sumped tank - definition?
Old 04-29-2009, 06:33 PM
Mark98SS's Avatar
Default Sumped tank - definition?
Is a "sumped tank" done by installing AN fittings at the bottom/rear of a stock fuel tank?
Old 04-29-2009, 06:39 PM
bgblockelcamino's Avatar
usually have a box built at rear of tank with fittings facing towards rear. same as a drag race fuel cell except utilizing a stock tank. typically use a 98 tank since they are metal.
Old 04-29-2009, 08:25 PM
Mark98SS's Avatar
Thanks, that's what I thought but I saw pics of a set up coming out the rear of a stock plastic tank & no sump box to an external pump & was thinking maybe it could be done on a metal ('98) tank too.
Old 04-29-2009, 11:40 PM
V8RX7FTW's Avatar
Like this is my rx7 tank that I just sumped. Just cut it out of sheet steel bought fittings and tigged it on.
Old 04-30-2009, 05:24 AM
White.Lightning's Avatar
Doesn't the sump portion have baffling to reduce the chance of a pump losing fuel under various braking/acceleration events? In other words, it keeps some fuel down there to feed the pump which is typically external on that setup.
Old 04-30-2009, 11:03 AM
V8RX7FTW's Avatar
yes i used the tank to baffle by using a hole saw to make my opening to the sump. this may it will retain fuel in the sump when it sloshes.
Old 04-30-2009, 11:05 AM
How many holes? Diameter?
Old 04-30-2009, 11:26 AM
V8RX7FTW's Avatar
depends on the sump size but i made 6 1.5 inch holes
Old 04-30-2009, 12:53 PM
Mark98SS's Avatar
Thanks, the pic is a big help.
