Regulator, Rail Questions...
Old 04-30-2009, 01:31 PM
TomM's Avatar
Default Regulator, Rail Questions...
Getting ready to install a 98 LS1 into a 66 Nova. This is pretty much stock for now. I am going to get new rails. Have read quite a bit about the regulators, etc. so jump in here and correct me if I am wrong.
I am going to use the stock line as the return line from the regulator, and run a new -AN line from the tank. I purchased a Rick's tank with the 225 gph pump. The regulator will be placed on the return side of the rail. All this will be done in -AN hose and fittings.
What is a good regulator?
What pressure to set regulator, 55-60 or what?
What size are the stock injectors, and can I increase them to how much? They probably need to be changed anyway.
Thanks,
T
Old 04-30-2009, 02:13 PM
Nasty N8's Avatar
I have a much simpler swap kit give me a call I will help you figure out what you need.
Nate
Quick Reply: Regulator, Rail Questions...
