FPR Required?...
FPR Required?...
Is a boost referenced FPR required on all builds or just the big ones?...
(im only looking for 450-500rwhp to start with)
ill be running dual walbro 255s... to a T70 Manifold Build on a stock long block... will I need a FPR of any kind or just run it direct?...
If one is required...what do you guys recommend for this mild build?...
while the BR fpr is not required, it sure would help. When I had the stock setup, my fp would drop 8-10 psi at the rails when in boost. Now, it doesnt go below 50psi and even rises with boost pressure.
