Injector and fuel pump question
Old 05-10-2009, 02:20 PM
reece0511's Avatar
Default Injector and fuel pump question
i am making future plans to run about 15lb boost on my ls1, i will use 6.0 heads, already cam, and intake. my question is will 60lb injectors and the 255 fuel pump be enough for my application. from what i read on most of the ls1 cars runnin that high boost they are makin 600 to 700 on the ground, just making sure there will be enough fuel for the car?
Old 05-10-2009, 07:53 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
60's will be OK for 6-700rwhp, but the single pump will come up short in the 600+ rwhp range.
Feel free to contact me about a custom setup for your car. I offer dual pump kits, custom lines etc. to give you a system to fit your exact needs.
Old 05-11-2009, 07:07 AM
reece0511's Avatar
roughly whats a dual pump kit cost?
Old 05-11-2009, 11:41 AM
ZL1Killa's Avatar
there is a sticky that I helped put together that can help you find your injector size... its on this main page . www.rceng.com and go to technical / sizing
Old 05-11-2009, 05:41 PM
LS1TECH Sponsor
Price is on my website in my signature link, but you should call me for personalized service & to discuss various options.
Old 05-12-2009, 06:45 PM
zapp168's Avatar
You may as well go overboard on the fuel system, I keep needing to add...add..add. Had I known where I would end up, I would have started with the fuel system. Mine is near maxed out at 570 HP
Old 05-12-2009, 08:07 PM
LS1TECH Sponsor
Mine is still going strong at 1000rwhp. Buy/build it once & be done.
Old 05-12-2009, 08:17 PM
conan's Avatar
My single intank walbro with a KB boost a pump was loosing fuel pressure @ 5,000 rpms/10#'s of boost. After dicking around with bandaids for the fuel system for a year, I spent the $$$ and got lonnies dual pumps. I can finally spin my engine to 6,700rpms with out loosing ANY fuel pressure. Do your self a favior and get a dual pump and forget about it. His pumps are top notch
Old 05-12-2009, 09:31 PM
reece0511's Avatar
conan roughly how much was your dual pump set-up
Old 05-12-2009, 10:06 PM
conan's Avatar
I paid $600 for the pumps, racetronix double pumper harness, hobbs switch, and return shipping, pittsburgh to utah. One pump runs all the time and the other pump kicks on when the hobbs switch sences boost. This is completely plug and play you don't have to cut a single wire. I bought a brand new sending unit from ebay for $120 (delfi unit) and sent it to him, 2 weeks later this came back http://mycarpics.shutterfly.com/244
Read my first post this explains my fuel troubles.
https://ls1tech.com/forums/fueling-i...ual-pumps.html
