Darn it car won't start
so I did the trap door for my pump install and I had a bucket with the metal tank oh well but I installed everything as the instructions said but now I am having the same trouble as some of the others on here. Car started up fine ran for about 15 minutes before taking it out for a test drive. While doing that it wanted to shift strangely and then seem to die out after a few seconds would pick up again. On my way back to the shop it just died and won't start again. It would crank for a second then die out again and won't crank (it will only be for a second again) unless I let it sit for awhile then it does the same thing over again. Things I did:
1)99 Ls1 -->LQ4
2)stock injectors-->60# injectors
3)stock exhaust-->STS 67mm turbo
4)stock fuel pump-->Walbro 255 w/Nasty performance hotwire kit
5)841 heads-->317's
6)Pacesetter longtubes w/x pipe-->stock exhaust with aftermarket Y no cats
(have this in another thread but this is basically a different topic)
1)99 Ls1 -->LQ4
5)841 heads-->317's
