Fuel pump upgrade
Fuel pump upgrade
I have an 85 Monte with a 2004 LS6. Right now I have a stock GN pump in tank with a regulator at 62 psi(stock GN is 47psi). I am looking to upgrade the pump because I believe it is losing pressure/volume at the top end and is running lean. I don't need a killer fuel system as of yet but do want something with more than the stock system has. I have looked into the Bosch 040/044 and they are way more than I need. Have also tried a Walbro and that was too much also. Any ideas? Thanks
