Need Help Carb are F/I
Old 06-04-2009, 09:36 PM
parryracing1's Avatar
Question Need Help Carb are F/I
Heres what im planing on doing i have a 2002 Camaro that im putting together imtrying to find an LQ9 are some 6.0L im having a th350 built right now and im going to run a 4000 stall converter and im putting a 12 bolt in with 4.11 gears putting in a 10 point wolf cage the motor will be a stock bottom end with the gm L92 heads and good cam still need to call cam company to get the right one.This is where im lost im hoping to make 550hp then spray the the car another 150plus so whats the best way to go can i make hp carb will it work and if i go with F/I whats the best intake and throttle body and how would i program it what the best system for tunning and how much will it cost F/I are carb i need help im new to this stuff that why i like carbs but these cars run mine stock with a 150 shot went 12.2s at 116 so can i get some help please what the best way oh and im putting a fuel cell in in case that matters.
Old 06-08-2009, 11:00 AM
Nasty N8's Avatar
FAST 90mm intake and a good fuel system. Plenty of options for local tuning.
Nate
Old 01-30-2018, 02:54 AM
dawgs74's Avatar
I’m doing the same a 370 flat top with 64cc ls3 heads.....I don’t know what kinda cam I should run. I wanna go dual plane but I’m probably at 11:1 comp any ideas
Quick Reply: Need Help Carb are F/I
