fuel injector+ fuel rails
Old 06-08-2009, 12:03 AM
mechanix565's Avatar
Default fuel injector+ fuel rails
quick question are the fuel injectors used in ls1 powered carsd like the camaro or T/a the same as the ones used on the truck intakes like the 5.3's in the tahoes reason im asking is because i have the complete setup from an 02 tahoe i plan to swap into my mustang and i have enuf hood clearance to clear the truck intake so i figure ill keep it for now but down the line i want to swap it to a car style aftermarket intake and jus looking to see if im gonna have an issue with my injectors and fuel rails
Old 06-08-2009, 11:39 AM
Nasty N8's Avatar
The truck injectors are shorter than the car inj. You can use the car inj. in the truck intake just need to space the rails up some. but the truck inj. will be too short in the car intake.
Nate
Old 06-08-2009, 11:53 PM
but the fuel line hookup and the injector plugs are the same between the two harnesses correct?
Old 06-09-2009, 10:49 AM
Nasty N8's Avatar
Nope the truck injectors harness is a different plug. Some of the trucks had dual inlets on the rails some were the same as the cars.
Nate
