what injectors?
what injectors?
what fuel injectors should i run on my 5.3l with a z06 cam and a single t70 turbo running on low boost like 4-6psi max using truck intake and truck fuel rails and truck harness motor has a stock bottom end which is why im running low boost. i hear you can run ford injectors? whats the deal with that and what ones do you reccomend? let me know thanks
