What base fuel pressure?
I am ready to get my car tuned, but I need to set my base fuel pressure. I am runnig a return style system aeromotive boost referenced fpr, a1000 pump, -10 feed, -6 return, 60 lb mototron injectors.
try 58 psi. then while it is running it should sit at around 51 psi. At this pressure you can get a lot of horsepower out of the 60's. You can run a little higher if you need more. I run mine at 62 base.
