which mustang injectors are a direct drop in for ls1?
Old 07-16-2009, 01:17 AM
unclebens's Avatar
Default which mustang injectors are a direct drop in for ls1?
which mustang injectors are a direct drop in for ls1? I've done some searching but still confused. By direct drop in I mean no changes to orings or injector clips.
So far I've heard the new mustangs have different clips but not sure what years exactly. I have heard the 03-04 cobra injectors do not use the same wire connector.
Anyone know if all the fuel injected fox bodies 1986-1993 are direct fit?
All svo mustangs?
All 4th gen mustangs (1994-2004)?
5th gen 2005-present?
Old 07-16-2009, 12:04 PM
allthrotle's Avatar
M9593F302 this is the ford racing part # Im running in my h/c/i car. I believe these are discontinued but im sure you can find a picture to give you an idea of what you need. I hope this helps.
Old 07-16-2009, 12:18 PM
FICINJECTORS's Avatar
we have these in stock in flow matched sets.. still on sale for 279.00
Old 07-16-2009, 12:34 PM
unclebens's Avatar
I've just been lurking on the mustang forums and see a lot of used injectors that I wouldn't mind getting as long as I know they fit
Old 07-16-2009, 12:38 PM
allthrotle's Avatar
Look at the fic's picture that is the injector you need. You just need to know what size injector you want and YES they are a direct fit. They plug right in. If you get bigger ones you'll have to have your car tuned for them otherwise your car's gonna run like ****.
Old 07-16-2009, 05:14 PM
unclebens's Avatar
Well when your looking to buy used injectors off of mustang people they don't have part numbers and often don't have pictures for you.
I just need to know which years and models of mustangs share the same injectors. I know not all mustang injectors are a direct fit.
Quick Reply: which mustang injectors are a direct drop in for ls1?
