MSD 6A with Fast XFI or not ?
I just bought a Fast XFI for my motor. 454 SBC stroker 600hp. My shift point is 6600 rpm. Will I gain anything with an MSD 6A box and this system? I was thinking the 6A because I don't need the rev limiter , the XFI will take care of that. I plan on using a Fast dual sync distributor. The car will be 99.9% street driven but I'm in over my head already so I might as well do it right the first time.
Another question is . I have 42 lb injectors (Their used but I will have them cleaned and checked) they should work for my engine ,but I was told be a tuner around my area. He would rather see 48 or 50 lb injectors on my motor. I was wondering what the opinions on this board were about it? Can I boost my pressure up or just get the bigger Fuel injectors? My pump is capable of 95 psi.
I started getting my fuel system together. I have a Weldon 1100A pump 135gph/0-95 lbs with aeromotive 100 and 10 micron filters and an Aeromotive 13109 fuel regulator . I'm going to run 10AN hard lines from an aeromotive sumped stock tank to a Y and bring the hose down to 8AN to the rails then 8AN to the regulator and 6AN hose to 6AN hard line back to the tank. Opinions welcome
Thanks Wayne
Thanks Wayne
