Twin Pump wiring question..
Im planning on runnin twin Walbro pumps in my 99 Camaro, the question is could you run two hotwire kits from say New Era and run one wire harness off of a micro switch or something? or do i need to just make my own wiring harness for the second pump?? i dont want to run them both while just cruising down the road i only want the secon pump on at WOT.. thanks guys!!
im sure the lonnies dual pump set up is the easiest and hastle free way to do this, but im still not sure why i couldnt run 2 of the hotwire kits and run one off a micro switch, 2 hotwire kits would be 120$ plus the 100$ a piece for the walbro 255lph pump, would be 320$ for a fairly easy setup that should be good for 800+rwhp correct? what is everyone doing just making their own harness and using the factory one for one pump? or running a hotwire kit for one and making their own harness for the second? i dunno about some of you but im not very patient with wiring but i can do it if i set my mind to it, im just trying to figure out what would be the best, cheapest way to do it.. it has to be done im pushing 500rwhp right now, and want to spray and still have room to grow and not have to worry about it, a 200 or 250 shot would be the biggest i would ever go, i appreciate the help guys!!
