car died and then its fine?
Okay I was passing a slow car up and went to pass it up. Going 35mph then jumped to 65mph because she was trying to not let me pass. 5 mins later going about 45mph. Car starts to die like it wasn't getting any fuel. So I limped it to the shoulder. Checked to see if anything was outta place under the hood and car. Found nothing, then went to start car and its fine. Drove 35miles back home and she's fine. I tested fuel pressure. Idle is at 40psi and under load just below 40psi. I'm still on stock injectors and I suspect the pump to be stock also. Any ideas? Went to check continuity of coil but not sure how to do that.
