Injectors not firing; VATS disabled. Common causes?
I'm using an e38 pcm on a 6.0 iron block and for whatever reason the injectors are not firing. Fuel pump primes, starter turns over and there is pressure in the fuel line. The injectors are getting 12v but I don't think they're grounding. All of my grounds are hooked up but I dunno what else it could be. Is there a setting in the ECU that does this? other than VATS of course. Are there any other common causes for fuel injectors to not be firing or other things I should check?
thanks!
thanks!
what was it man? i have the same exact problem, i know the three grounds are hooked up behing the driver side head one behind the alternator one small one to the driver side fire wall and the one for main battery ground and no fire to the injectors, i cant figure it out, i hooked up a noid light to the injectors and nothing. please help
