Would this work for wiring in a dual 255 setup Mighty Mouse style??
Old 08-16-2009, 07:32 PM
vipvegas's Avatar
Default Would this work for wiring in a dual 255 setup Mighty Mouse style??
Im using mighty mouses writeup and wanting to do the dual setup on 01 383 stroker with sts kit but turbo is now a mpt76. This vehicle has the stock sts wiring kit with a 1psi switch in place. Can I use the exisitng 1psi switch used for the sts pcv which Im deleting to run to the relay for the second fuel pump as trigger, then run 16 gauge from battery to power new pump?
What are others using for this setup, Mighty Mouses writeup was awesome just wondering on wiring never used hobb switches before??
