Injector ratings
LS1TECH Sponsor
The answer is... "it depends"
Typically most injectors are rated at 43.5psi & this is preferred as a common point of reference.
Some companies are marketing "high flow" injectors that are just using a different published pressure rating. This has mislead a lot of people into buying a smaller injector that they intended.
Always verify the checking pressure to be sure.
FYI, changing pressure from 43.5 to 58psi will net a 15% increase in flow.
Just multiply or divide by 1.15 to get your new values.
